leveling kit wheels and tires
ridehuff
bismarck ND
ok, so i put a leveling kit in my 99 OBS tahoe 4door 4x4. i brought the front end up 2 inches and the rear block of 1 1/2 inches. can i fit 16x10 wheels with 285/75/16 mud tires? was told that i would have to pound the back of the wheel well in the front and screw screws in to hold it back. will the wheels and tires fit? please help with input. i already bought the wheels and tires but if i mount the tires on the wheels then i cant return them.
99denali
alabama
It should run just fine, i know some guys on here have ran 285/75/16 on stock wheels with just the bars cranked. Just a lil rub.
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
What leveling kit did you put on th front? I know alot of guys do the TB crank but you can only get about 1" w/o putting alot of stress on the front end....
smrr1
running 285/75/16 nitto terra grapplers with no lift or cranking and no issues. you should be just fine. (2 door Z71 package tahoe)
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
I think I might do a TB crank just 1" just to get a more level look on the Yukon...
I also found a guy on CL selling a new Performance Accessories BL lift for $100...
Model #123, Now is that the 3" or 2" ???
992door
Greenville, NC
you will never fit them without doing a good amount of cutting. i think. I am only running a 9 wide and i still rub and had to cut some.
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
R
ridehuff
bismarck ND
I have a ready lift leveling kit and block in the rear. like i said the front end came up 2 inches and the rear 1 1/2 inches. i am going with a 16x10 wheel with toyo open country m/t 285/75/16 (33x11.5). are the rims going to be too wide to make turns? if i mount the tires on the wheels there is no return possibilities.
---------- Post added at 11:57 AM ---------- Previous post was at 11:54 AM ----------
now does it make a difference between a 16inch and 17inch rim? ur useing 17inch and im using a 16. is there a difference in the wheel wells for a 2 dopor and 4 door? i have a 99 obs 4 door tahoe
Landchipper
AL
Tire calcs - Hope it helps
I like to use this site when looking into tire changing.
The site is
http://www.1010tires.com/TireSizeCalculator.asp
And the chart for this discussion is
Stock Tire - 265/75R16 >
Search Tires Tire 1 - 275/70R16 >
Search Tires Tire 2 - 285/75R16 >
Search Tires Tire 3 - 285/70R17 >
Section Width: 10.43 in 265 mm
Section Width: 10.82 in 275 mm
Section Width: 11.22 in 285 mm
Rim Diameter: 16 in 406.4 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7 - 8 in
Rim Width Range: 7 - 9 in
Rim Width Range: 7.5 - 9 in
Overall Diameter: 31.64 in 803.65 mm
Overall Diameter: 31.15 in 791.21 mm
Overall Diameter: 32.83 in 833.88 mm
Overall Diameter: 32.70 in 830.58 mm
Sidewall Height: 7.82 in 198.62 mm
Sidewall Height: 7.57 in 192.27 mm
Sidewall Height: 8.41 in 213.61 mm
Sidewall Height: 7.85 in 199.39 mm
Radius: 15.82 in 401.82 mm
Radius: 15.57 in 395.47 mm
Radius: 16.41 in 416.81 mm
Radius: 16.35 in 415.29 mm
Circumference: 99.39 in 2524.5 mm
Circumference: 97.86 in 2485.6 mm
Circumference: 103.1 in 2618.7 mm
Circumference: 102.7 in 2608.5 mm
Revs per Mile: 657.3
Revs per Mile: 667.7
Revs per Mile: 633.5
Revs per Mile: 636.0
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.9 mph 101. km/h
Speedometer1: 57.8 mph 96.3 km/h
Speedometer1: 58.0 mph 96.7 km/h
Speedometer Difference: -
Speedometer Difference: 1.582% too fast
Speedometer Difference: 3.756% too slow
Speedometer Difference: 3.349% too slow
Diameter Difference: -
Diameter Difference: 1.55%
Diameter Difference: 3.63%
Diameter Difference: 3.25%
BigDaddy13440
Rome, NY
The 285's will fit fine, but not on those 16x10's.
As you see by the post by Landchipper (great job, btw!), the 285's aren't meant to be run on a rim more than 9" wide, the beads may/may not seat right.
I've got my 285/75/16 Yokohama's (a full 33" from the factory, BTW) on some 16x8 MB Blitz wheels, with a 25mm positive offset, and they rubbed, even after cranking my torsion bars a good 2". I maxed them out (about 2 1/2"), hammered the trailing edge of the fenders in, and cut my front bumper and lower valance for clearance. No rub.
If you use a 16x8 wheel with a factory offset (-6mm), the 285's will fit, and won't rub on the control arm, either. I think 305/70/16's might fit as well, if you want the wider tire. But 16x10's, not without some sheetmetal work.
Can you exchange the 16x10's for 16x8's?
Lowbrad
