Sorry man forgot they don't have the magnetic ride up front. You just need the U shaped lower spacer. Find the lowest priced spacer in billet aluminum or powder coated steel on eBay. Look for a 1.5" one and it will measure 3/4". Skip those instructions and follow these.
Remove wheel, unbolt two 15mm lower strut bolts, pry down on lower arm, slide spacer in between lower arm and strut, install with new boots or stock if you have enough length on threads, install wheel, get alignment.
That's sort of what I thought. Thanks for all your info and expertise.
