Lift Keys, 2" Spacers, 33s on 20s
2005SnowKon
Fort Collins, CO
For your stock wheels to stick out maybe a 1" wheel spacer. If you want aftermarket then you need to compare the rim width and offset choices. Most of the time you would want a +0mm offset.
What will a 0mm offset do for me?
Sent from my SPH-L710 using Tapatalk 2
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
For example if you have a XD series 20x9 wheel and they offer -18mm, +0mm, +18mm. The -18mm will stick out about 1.5", the +0mm will stick out about .6", and +18mm will look just like stock.
2005SnowKon
Fort Collins, CO
So I should figure out what I want first then talk to a place that sells rims
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Yea if you want new wheels then get some that offer a +0mm offset, if your going to keep your stock wheels then look into a wheel spacer. As far as tires are concerned either Nitto Terra or Trail are great tires. I prefer a all terrain tire over a mud tire unless its a fully lifted truck.
2005SnowKon
Fort Collins, CO
+0mm would br the better choice then? Sticks out alittle but not too much where it lookw funny?
wreedps
Is your Yukon a 2wd?
---------- Post added at 07:50 PM ---------- Previous post was at 07:46 PM ----------
Z71/denali/escalade top pic vs. LT/LS/SLE/SLT stock
They are taller and have more coils, about 17.5" to 15". They also handle 800lb more payload. Hope this clears up questions about z71 springs.
So could I just swap the Z71 springs into my 2wd Tahoe?
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
My Yukon is 4wd and yes you can swap the Z71 springs in your 2wd. If your looking to lift your 2wd just with Z71 springs you will only gain about 1/4" rise. To lift your 2wd drive with Z71 springs you also need a 1.5" lift spacer and 3" lift spindles. Let me know if you need more help.
BlackDenali04
Dud your Yukon looks awsome i want this kinda lift on my 04 yukon denali with 33". Do you think all this stuff would work on a AWD 04 Yukon Denali?
middelgriff1
Maryland
I went with 2" spacers with my stock wheels and loved it. Looked sick and then switched to 0 offset wheels and it brought them back in to 3/4" outside of wheel well
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
You can lift a denali with the same keys and spacers. Some say above 2" lift can cause vibrations on the AWD but there are plenty of trucks running level kits with no issues.
sequoia
