Lifted/Leveled 2021 - Postem Up
olyelr
Elk Rapids, MI
Here is a 1.5” level on a ‘22 tahoe high country without air suspension, with 305/44/22 toyo at3’s…
VAguy68
Love it!! Seems like 35x11.5's are hard to come by. Where did you get them? Also, is that rear bumper and exhaust part of getting a 6.2 now on the Z71??
Z71-HOE
They are hard to find for sure. My local tire shop has a set put back. I’m pretty sure the 6.2 Z71 get the dual exhaust. We added it to mine.
fntiger
How’d you get a lift on the 6.2 with the adaptive air ride?
RHStansbury
Annapolis
'21 Yukon XL with premium smooth ride suspension, no air or magneride. Rough Country 2" front, 1" rear kit with 275/60r20 Nitto Ridge Grapplers on stock slt rims
This looks so clean, very well done. How's the clearance? Think you could have snuck the 275/65s in?
R32driver
That's funny I never actually checked the clearance with these new tires. Just did and I do not think the larger tire would fit without rubbing. As is at full lock there is maybe 5/8" gap between the tire and liner. I can fit my index finger in there but that's about it. I was fine with removing brackets and using zipties to hold back the liner on the '11 burb but this just wasn't going to fly on the '21, whether anybody knows it was done or not
olyelr
Elk Rapids, MI
Welp…a 5/8” gap would indicate roughly a 1” taller tire could possibly fit, if its the same width (which is a 275/65/20).
R32driver
Yes I think they would fit but if it ends up with maybe say an 1/8" gap they would surely rub if you hit any kind of bump or anything while turning.
olyelr
Elk Rapids, MI
Not necessarily. But yes, will certainly be close for sure, if they do fit.
raejay
