Lifted leveled 2wd
Nortex
I'm looking at maybe doing a small lift and 285/70. Anyone have pics of suggestions on parts?
Coatwolf
Eastern Virginia
I liked the Readylift kit - 2.5" torsion and 1" or 1.5" coil spacer in the rear - I added 285 BFG AT KO2's on a 16x8 pro comp 7069 wheel rides great and sits perfect height imo
I think the READYLIFT kit is part # 69-3005 easy install too
atothez
I did 3 inch lift spindles - http://www.ebay.com/itm/1999-2006-C...del:Suburban+1500&hash=item3cd256e2ad&vxp=mtr
And I did 2 inch spacers in the rear - http://www.ebay.com/itm/Black-Alumi...del:Suburban+1500&hash=item3cedd78614&vxp=mtr
With the spindles in the front you can use stock length shocks. You will need new rear shocks or shock extenders for the rear. I would suggest Bilstine 5100's all around. That is what I went with and they have been great.
Also, I got rear sway bar links for a jeep tj - this was to compensate for the rear lift - http://www.rockkrawler.com/ProductDetails.asp?ProductCode=RK01941TJ
I am pretty sure these are the ones I got but do some research and you will find the correct ones
gottaluv01tahoe
