Lifter noise
K9Gunner
K9Gunner
I had several things down. High pressure oil pump installed. Water pump replaced. Belt replaced. Lower control arm replaced. And safety inspection. Total was $1390 I will look at receipt and get you exact on HPOP.
And yes it’s 4wd
89Suburban
Bull in the china shop
SE PA
That seems like a damn good price to me for all that work. I’d like to get my pan gaskets replaced, oil pump, pickup tube oring and that oil splash shield thing too. And I am pretty sure my drivers side engine mount is wiped out. Being 4WD I am sure the front axle and crossmember have to be dropped to do all that which will be a lot of labor. :(
K9Gunner
K9Gunner
My mechanic is a good friend so he helps me out on the labor and if I pay cash it’s even better. Only thing I have left to do on the Yukon is replace the rear main due it leaking a little. After that I think I will be ready to put some money into extras.
Awesome. Glad the oil pump did the trick.
K9Gunner
K9Gunner
Ok here’s the run down on my Yukon:
Oil Cooler Gasket (2yr warranty)
Oil Pan Gasket (2yr warranty)
HP Oil Pump (1yr warranty)
T. Cover gasket (2yr warranty) can someone explain what this is???
H20 Pump (LT warranty)
Heater Hose (2yr warranty)
6 quarts Dexos 5w30
Oil Filter
2 Gallons Antifreeze
A/C belt
Drivers Inner T-Rod (LT warranty)
NC State Inspection
Total $1,393.50
I think that’s is a good price for all that work. What’s your thoughts?
harveje
dang good price esp for a 4wd due to the front diff has to drop down... probably should have done a crank seal too, which they may have.. they tend to leak over time. Whoever is doing the motor mount... it's a pita and if you diy a lift is great along with a few jacks.. it's like putting a 10" square block in a 4" hole.....
Front (crankshaft) seal generally comes as a component of the timing cover gasket set. I would be extremely surprised if they didn’t swap it out. That’s standard practice.
K9Gunner
K9Gunner
About 1,000 miles since the work and still no lifter noise. It’s been 20* some mornings and it makes no noise at all. Can’t say enough about the HPOP work he did. If you have any lifter tick I highly recommend doing it.
davemitchell117
