Lights out
warhorse
I've been having an issue with my 07 tahoe. On the first occurrence I was driving on the highway and every light in my cluster lit up along with all interior lights. I pulled over and turned the truck off hoping it would reset and then I couldn't get it started again for about 10 minutes. The key fob wouldnt work and i tried resetting the computer to no success until I opened the passenger door and the truck decided to act normal again.
The next occurrences are similar in nature. After turning the vehicle off it goes completely dead, key fob will not work, no interior lights and not even a click when trying to start it. The passenger and driver door window switch areas click very fast while the truck is dead. It will do thisbfor about 10 minutes then after disconnecting the battery it will start and operate normal again.
I'm curious if anyone else has dealt with a similar issue or if anyone might know where this electrical issue is originating from. There are no codes to go from either.
kbuskill
NE. FL.
Like he ^^^ said... check your grounds and probably replace/upgrade your battery cables.
W
warhorse
Double checked the grounds I could find. Going to try new cables in the next few days.
mgladdis
