LoJack on new vehicles
nomech
Senior Member
I know this isn't limited to new vehicles, but this question is specifically for new vehicles.
During my research, I'm noticing that some dealers are 'adding on' items that they want to upsell...LoJack, window tint, PPF, etc...
I spoke to a dealer and they said LoJack is one of the things that all cars get once they land on the lot. I'm sure they say that to make it 'harder' to remove if the customer doesn't want it.
I had one dealer explain that they'd include the LoJack for free for 3 years at no cost and sure enough in their final quote the line item for LoJack was removed. Why would a dealer still throw in LoJack if I specifically stated I don't want it installed? Is this something wired into the vehicle wiring harness and a hassle to remove? Is it inline in the OBDII jack and easy to remove?
Now I'm not sure what to think about a vehicle with LoJack wired into the factory harness (likely spliced) and interfering with manufacture wiring. If it is instead installed inline with the OBDII why not just say 'ok, it can be removed' and just disconnect the LoJack device?
LegalBrief
They put LoJack in as a way to track the asset on the lot (dealership).
It’s super cheap to the dealership, and quick to put in, (less then 5 minutes, faster if you do dozens a day) then dealer gives you bs about removing it.
My view is don’t pay for it, then you remove, so you know it’s gone, there is an OBD splitter that you remove and toss the LoJack in the trash, don’t forget to peel the sticker on the door jam, less then 5 minutes to take it out nice and neat.
LoJack is a parasitic drain, not having that in my truck. If someone steals my truck the last thing I want is the truck back. Insurance discount isn’t real, you get the same discount from onstar.
Stbentoak
Unless you physically undo OnStar...they know where your vehicle is at all times. Period. Whether they will tell you or not depends on if you are subscribed and to what level.
N
nomech
Senior Member
The dealer can use onstar to locate me?
I'm not as concerned with the dealer knowing my location IF they can look it up using onstar, I'm more concerned with the LoJack install and splicing into factory wires especially when I stated that I am not interested in that add on.
Onstar is built into the vehicle by GM and I'm not worried about that wiring.
Stbentoak
Not your dealer..OnStar corporate....Just saying no reason to ever buy Lojack with OnStar onboard. Just another reason for the dealer to add cost to your delivery. If they installed it... they can uninstall it....
N
nomech
Senior Member
Yeah, onstar corporate I get that they can track.
I also agree that they can install it, I'm just curious about the actual install. Does it involve splicing into factory wires or is it just an inline wire harness/LoJack device into the ODBII port that can be quickly removed. Sounds like the OBDII port is the most common way to do it based on what @LegalBrief posted.
LegalBrief
there is an OBD splitter under dah that you remove and toss the LoJack in the trash, don’t forget to peel the sticker on the door jam, less then 5 minutes to take it out nice and neat.
SmoothADetailing
