mattbta
I posted the same response when you asked the same question in another thread months ago. If you're pulling the intake to inspect the pigtail, put an OEM sensor in it. Then do a cam/crank variation relearn for funsies! (My chinesium cam sensor still exhibited problems even after relearn, OEM fixed it!)I have the same issue. Had to have the trans rebuilt last April. While out, they find the leaking main rear oil seal which we could see prior. They replaced it. Also found the camshaft position sensor wires baring copper. The insulation was gone. I asked and they said they can splice in a new pigtail so they did ... great. Now I have the issue you have. Not everytime but maybe 50% of the time. Cranks without start. Maybe a pop. The second attempt starts immediatly. Just like yours. Just like you describe.
I was suspecting that possibly the wiring was mismatched on the pigtail. I am not overly educated on how the cam postion sensor exactly works but I have the factory manuals and understand the sequncing of fuel/spark based on parameters of camshaft and crankshaft. If a wire was inadvertly miswired, would it do this? That I cannot yet get an answer. I have to pull the intake off to redo that pigtail. Maybe the CMP has failed at the very time they touched it? Unlikely but possible.
I can say this, it was perfect until the wires were touched/repaired. I did not go back there with this problem because I am leary of what could happen. The trans works fine and the rear oil seal is tight. Just this. I am putting up with it for now, but irritating.
Maybe someone has additional info that can help us?
-Oldchev
Unlikely the truck would run well at all if the wires weren't correct.
