Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Curious if someone could give me part numbers for longer sway bar end links for my 04 Tahoe. It's lifted around 3" and I've read that the longer links will help the ride some.
The stock height front sway bar links would work if you get drop brackets from the frame like they use on full lift kits but made for 1-2" key lifts. I think you could make them pretty easy, they look like "C" brackets
This forum is awesome! Piecing together my lift, going to need a set of those longer end links for the rear to go with my 3in coil spacers! Thanks yall
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
