Looking at doing my own retrofit on headlights
fatboyracing
I am going to try to do my own retrofit on my head lights, any suggestions would be great.
I am going to use the retro fit source for the projectors I think unless i get other suggestions
2010 Tahoe
01Konvict
Boats n Hoes
Raleigh/SML
Do you have a Tahoe/burb or Yukon headlight? Also what's your budget?
I did FX-Rs in my stock Denali headlights and the output is really amazing!
F
fatboyracing
Tahoe/burb light
My budget idk cheap I am poor well or at least my wife says we are so the less I spend the less I hear from her
I think I am about to pull the string and order the mini h1's from the retro source
TheAutumnWind
Tahoe/burb light
Check out the closeouts section.
http://www.theretrofitsource.com/closeouts/b-stock-morimoto-mh1-6-0-projectors.html#.VZQrd9zF__A
http://www.theretrofitsource.com/closeouts/morimoto-3five-h1-bulbs.html#.VZQr4NzF__A
http://www.theretrofitsource.com/closeouts/fast-bright-amp-ballasts-50279.html#.VZQsbdzF__A
F
fatboyracing
Thanks..
I just ordered the kit for 282 with headlight sealer
I need to find some headlights to use
and then see what I am going to do for drl and turn signal bulbs I would like to upgrade them while I am at it
01Konvict
Boats n Hoes
Raleigh/SML
TRS is running a special over the weekend. 20% off code July4th and its good from 4th-7th
Also if you went with the h1 then make sure you open up the bi xenon flip tabs so it doesn't get stuck and aluminum over the holes in the cut off shield
F
fatboyracing
i did go with the h1 what do you mean by that are you saying kind of leave them in like the high beam mode all the time
01Konvict
Boats n Hoes
Raleigh/SML
The bi xenon flipper gets stuck on low beam but to prevent this issue you just bend the L shaped ears away from the flipper. It has a rod that goes through the flipper with a spring attached to the solenoid then the rod is held in place at the L ears. Bend the L ears outward away from any contact with the flipper.
The holes that need to be covered in aluminum tape are the L tabs that hold the solenoid. They will show up as bright spots in the air like random high beam spots. Let me know when you get the lights in your hand and can explain the setup a little better.
kyle09
