Looking for front brake pads with lots of bite - dust and wear life not big priorities
LurkingLuke
WA
2013 Yukon.
Is OEM the way to go? My front pads are at 25% life remaining. I want my new pads to stop me in a short distance. A search on this topic [here] led me to drilled and slotted rotors, which my daily driver definitely does not need, and in fact might even achieve the opposite of what I seek.
I just want grippy pads from cold. Anyone recommend a certain brand or model?
buckwild27
2013 Yukon.
You can get the PPV pads and rotors. If you want extra stopping.
Pads
BENDIX PBD1194 rear
BENDIX PBD1363 front
Pads
POWER STOP Z371194 rear
POWER STOP Z371367 front
Rotors
BENDIX SDR5729 rear
BENDIX SDR5582 front
LurkingLuke
LurkingLuke
WA
Pads
BENDIX PBD1194 rear
Pads
Rotors
BENDIX SDR5729 rear
Wow, great info! Must I do rotors or can I use PPV pads on a civvie Yukon?
buckwild27
You can, the real question is do you want too? For me a brake change is pads and rotors, but I run my truck hard. Driving style is more like a rally truck then a normal driver.
j91z28d1
for what it's worth I just had to take off a set of raybestos E3 pads, I left the rotors and switch to a pad with less bite. it was confusing my regen/ebcm setup. (it's a hybrid thing only) and went with Warren quiet pads with good results in oem like feel. but if you want good initial bite, might be worth a look.
to bad you aren't near San Antonio I'd give you these.
hellz
