Looking for softer ride wheel setup
comtech5
OEM tires I have now are 20" BridgeStone Dueler H/L Alenza and I love them but am looking for a more luxurious ride! I was thinking about going to a 17" rim with the same model tire. The 17" rim I am considering is GM part #9596050 and comes std on LS. That will give me an extra 3" of cushion. BUT wait...can I go with 16 inchers and get an even more plush ride? Any advice on this appreciated! I know the appearance and handling of the vehicle will suffer, but I am not really concerned so much about that.
soulsea
Administrator
Bar
I could be mistaken but unless you plan to substantially under inflate the tires, which obviously is not recommended, I don't think you're going to see as much improvement in the ride softness as you think.
In my experience since I've owned these vehicles, is that the relationship between ride softness and tire size isn't a linear one. Meaning that (assuming one keeps the same overall diameter) the amount of increased stiffness observed when going from let's say 17" to 20" wheels is much less than when stepping up to 22s. For example, I noticed almost no ride difference going from the oem 18" setup of the hybrid to the 20" setup of the Denali. A very slight increase in stiffness when going to the 22" oem wheels, and a huge difference going to 24" with 295/35/24 tires.
So the graph is more a curve, with the 16/17/18/20 inch wheels at the flatter part of the curve, then as you go bigger the curve steepens ... if that makes sense?
No doubt a small improvement will be achieved in ride softness, but probably not enough to justify the compromises, be they esthetic or handling related. 2 cents. :)
akbrener
Baltimore, MD
what options do you have? I see its LTZ but 4wd... maybe your issue is in the shocks/springs.
I have the "premium ride" option with 20's and it actually feels better than my honda accord. Didn't change much when I went from 17s to 20s. Alot more stable on exit ramps.
I would not go under 18" if you go that route, but like said above, probably wont make a huge difference.
slm987
