Looking for some expert advice
Big_THoe
Just installed a new K&N high flow cold air intake and the engine growls at random speeds, not just open throttle. Pulling from a light and easy on the pedal it growls, shifting from 2nd to 3rd it growls, open throttle this thing sounds like a T-Rex. While I love the sound at OT, the other instances are a bit too much!! So my question, since I’ve installed it and can’t take it back, would a smaller Filter fix my issue. I don’t have a ton of options as the Flange diameter is 6 inches but I do see smaller units available on the K&N site.
jerry455
I used the mini kit, just the intake tube from the throttle body to the stock air filter housing and a K&N filter, stock Suburban sized. It sounds great. It has a nice growl when accelerating. You might see if another brand or type of filter would fit. I know some vehicles use a paper, stock, type of material.
RST Dana
OH
Changing filter types probably won’t make the difference you are seeking. I covered one of the openings once years ago, leaving only the opening toward the wheel well. It did reduce some of the growl, but not all.
lilbit1984
