Confirmation that part 25807743 is the correct replacement part for the driver side instrument panel trim plate for those that want to go with the Z71 look over the fake wood look. Installed this evening.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
---------- Post added at 09:13 PM ---------- Previous post was at 08:59 PM ----------
Here is my “FINAL ANSWER” on replacing the eight fake wood trim parts with the Z71 trim parts on a 2010 Tahoe LTZ. These same part numbers will work on a 2011 Tahoe LTZ. This list does
NOT apply to 2009 and earlier models.
Driver side instrument panel trim plate (dash area) -- 25807743
Center instrument panel trim plate (dash area) -- 25807745
Center instrument panel accessory trim plate (plate that goes around the Radio/AC/Navigation spot on the front center console) -- 25807746
Center console cupholders/storage compartment -- 20951471
Driver side front door switch bezel -- 20877680
Passenger side front door switch bezel -- 20883864
Driver side rear door switch bezel -- 25909747
Passenger side rear door switch bezel -- 25909753
Since this part has been mentioned in this topic, I thought I would mention it again in this wrap-up post: Passenger side instrument panel trim plate (dash area) -- 25807742, as far as a 2010 or 2011 Tahoe LTZ is concerned, is not needed.
The only warning I want to mention is that if it is possible to install extended towing mirrors on a 2010 or 2011 Tahoe LTZ and you have them installed, parts 20877680 and 20883864 may not be correct; I just don’t know.
I will post pictures of the interior of my vehicle as soon as possible, although it may be as late as this weekend before I have enough time.
