Looking to cam my 03 tahoe
Jbsavage
So I'm looking to put a BTR or a Texas speed stage 4 cam in my 03 tahoe z71. It has 132k miles on it. Does anyone have any input on any things I may want to upgrade while doing this. The transmission is getting built right befor I do the cam swap and I'll be putting a circle D torque converter in. I know the kits come with most of what I need to do the swap just wanted some input from any one that has done this and what your thoughts are. Thanks in advance
fasteddy
Are you gonna pull the heads? I would. Because that increase of a cam requires new springs and I would pull the heads and have them rebuilt.
And I would throw in a new oil pump and timing chain while you're in there.
And headers if you can swing it.
5.3 + cam + headers + stall = good power.
With that large of a cam, you'll definitely need an appropriate converter. Circle D can spec you something. Normal items whenever an engine is opened up for a cam would be new oil pump and timing chain. The cam itself would require valve springs and possibly custom-length push rods. I highly recommend larger diameter chromoly push rods, even if you determine stock length to be fine. I'd recommend upgraded rocker trunnion bearings as well. As Greg mentioned, have the heads redone. While they're at the machine shop, have them shaved to raise the compression. Raising the compression to around 10.5:1 would really help to reduce the low end power lost from the large cam as well as increase power across the board. Doing this is up to what grade of fuel you wanna run, though.
GMT800 SUV/Trucks
Yep, you will live at the 93 octane pump moving forward, but hell, who cares. It is your rig, go for it.
Jbsavage
Jbsavage
Thanks for the info guys I definitely planned to do the heads I just forgot to mention that. I had debated on putting a set of texas speed heads on it but I dint know if the budget will allow for that at the moment. I never even thought about the timing chain so thanks for that. I will be running long tube headers for sure. Thanks alot guys
Mudsport96
40.923,-89.488. Illinois
Watch this video on the comparison between the truck cams. I would personally do a stage 1 or 2, with 3 you see a significant low speed drop ( like 25 lb ft of tq) below 3000 a stage 4 will be a bigget loss. Yeah a 3000 converter will get you passed that when accelerating, but highway cruising will put you in that area. Also what gears do you have? It looks lkke you have aftermarket wheels, how tall are the tires? You may need to regear as well to get full benefits of a cam ove the stage 2.
ks03
Fool Excess Member
Yes... Unless he’s just trying to get a super rowdy idle
Bigger than a stage 2 seems like it’d be hard to take advantage of but then if I had a 5.3 I’d be thinking torque cam and skip the converter for a daily driver... but what fun is that
Jbsavage
Jbsavage
Yeah I have 22x12 rims with 33x12.50xr22 tire not 100% sure what gears are in it at the moment I just got it a couple weeks ago. But i plan on regearing because i plan on lifting it with 35 inch tires on the 22s that are on it now.
I have a btr stage 3 truck cam with beehive valve springs and 3000 Circle D convertor. Don't forget to upgrade your trans cooler too.
My parts list--
BKraft
