Loose steering and Oscillation
GangstaCowboy
Hello-
Experiencing some steering issues in my Yukon. Some back ground info: has 6.5 inch lift with 37 inch tires. While driving the steering will wiggles around on its own and I can feel some oscillation in the tires when going over large bumps or puddles of water. Sometimes the movement in the steering wheel is a little scary when going through water as the wheel will jerk from right to left. I was going to try replacing the front shocks with something newer to see if that helps but i feel like the issue is definitely in the steering component somewhere. Truck has 150k miles on it and I have no idea if anything has ever been done to the steering. No problems turning or response besides the jerking motion the wheel makes some times. Thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
After ensuring you have no loose parts I would strong strongly (yes twice) suggest you get yourself a steering stabilizer installed.
G
GangstaCowboy
Yeah, that was one thing I noticed being absent. I had and aftermarket one on my lifted F250 and made a world of difference. Stabilizers do not seem to be stock on these, is there a good aftermarket kit you recommend? Rancho?
b18cls1
