Loose Steering
orange57
The steering on my 2000 Limited is really loose with quite a bit of play in the steering wheel. Today, I had my wife come out and move the steering wheel back and forth some while I looked underneath. All appeared to be tight, but there was a clunking sound coming from the gear box. Is this normal to get some clunking? or is this an indication that the gear box needs to be replaced? The truck has 146K on it. Pretty sure it is the original.
Thank,
matt
jake 03
You may just need to tighten the gear box lash.
On the top of the steering box there is a allen head stud with a lock nut. Loosen the nut and screw the stud in until tight then back it off 1/2 to 1 full turn and tighten the lock nut.
That should fix the loose steering box issue.
O
orange57
So is the clunk indicative of a failed gear box? If so, I'd rather replace it for a long term fix as opposed to a bandaid.
Monstar_est87
City of Angeles
O boy... I heard a clunk outta my baby the other day... Thought it was an alignment issue... AC Delco gear box part number..?
O
orange57
sounds like a gear box is in my future then. Thanks again!
kcb37
If you don't have one get a pitman arm puller.
It will make your life 100 times better getting the pitman arm off the gear box.
Cost $10 or $15 from a parts store.
blanchard7684
