loosing trans fluid
rede30
Southern CA
edit, there is trans fluid in the dexcool. The only thing that can cause this is the radiator, correct?
3genpio
I am losing trans fluid in my 01 yuk. The front and rear of the trans does not look dry but not wet enough to account for how much I am losing and I don't leak while I park. ...........?
check you lines. next to starter there is a metal clip that hold both lines together, mine was loosing fluid just under this clip.
brgds
R
rede30
Southern CA
my dexcool t is defiantly full of trans fluid. Has to just be the radiator, right?
Mac
NY
Yes you're right, the Radiator houses bunch of stuff.
You have the oil cooler, transmission, steering, and regular coolant.
You could have a internal crack......(might need new radiator)
Rubeng0315
