Loss of power uphill or under a load
Xanzgod
Xanzgod
Still would like to see the fuel pressure tests results and the cat back pressure tests.
Got it. I'll try to do this next week. And see where I am. I just got the Washington about 2 months ago. And I hate it here.
Still trying to find a good exhaust shop to do my bullets and do the back pressure test now.
Can I check the fuel pressure with my data logger? And if I can where is it supposed to be?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
If fuel pump itself is good the KOEO pressure should be in the neighborhood of 50-60 psi. Others may say a little less but I am telling you what I like to see. When start I like to see at least 45-50 psi and prefer to hover right at 50 psi. Can you check on your data logger? I don't know. I have a Tech 2 and just became familiar with that since being back at this forum.
Fless
Super Moderator
Elev 5,280
The fuel pressure specs for KOEO (key on, engine OFF) vary depending on gas-only or Flex Fuel capable, so keep that in mind. The fuel pumps are different.
Do the fuel pressure test first if you can. Easy peasy. You can rent a gauge from a local auto parts store; most have rentals for only the deposit, which is refunded when you take the tool back.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Plus, if you can get a long enough hose for the manual gauge and bring it out at the back of the hood and tape to the windshield you can watch the pressure while going up a hill when you say you experience the problems. If you can monitor with a Tech 2 or something equivalent, even better.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Ok, I have ALLDATAdiy.com so I did look up the specs there for my 2002 Tahoe flex fuel. Engine code Z is 48-54 psi but if you have engine code V, T or U it says the pressure should be 55-62 psi.
SnowDrifter
Washington. The starbucks side not the desert side
Really? The last 4-5 times I bought plugs for my last 2-3 vehicles they were gapped at the correct spec when I got them. I do always check them for correct spec and not assume that they could not have been damaged/bumped during manufacture and shipping and stocking but I guess I have been lucky.
Back in the day I had to gap plugs all the time but I also set point gap as well and adjusted timing and adjusted carb.
Weird. Probably 8 out of 10 I need to tweak it. And there's the occasional time where one was dropped and the gap is between cunthair and short circuit lmao.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I get a lot from RA and we know how well they take care of everything when they ship. I have been lucky. I do check and never assume.
avalonandl
Troy, MICH & Naples, FL
Are your plug wires making GOOD contact... I mean real good contact. The symptoms your describng could also be from plug wires not making full contact in the coils.
rockola1971
Indiana (formerly IL)
Getting a check engine light? How about a blinking one when going uphill? Check plug wires to make sure they are fully snapped on, on both ends. Coil and at the plug.
andrewjles
