Lots of Voltage drop after capacitor removal.
whitehoe01
thats odd. hid need more power so you should be dimming just as much as you were.. but hey its a good thing for you.
take care of your big 3 and perhaps buy a high amp alt. they're rather cheap on ebay (under $250) great price for 220+ amp alt
MOBmentality
Has a $25,000 Punch
HID use more amperage to fire but equal or less after they ignite.. if they used alot more amperage then they wouldnt be plug n play because they would need a larger fuse.. most hid kits us less amperage than halogen AFTER warm up.. so this might be part of his low voltage spike solution..
But i agree... +1 to not needing more than a big 3 for his amp draw.. and his battery possibly being a crap battery from the start
DenaliAK
Colder than you
Alaska
HID's power is kept constant, at least in theory, by the ballasts, so this makes sense.
jwaldo432
jwaldo432
Texas
ok so I did my Big 3 Upgrade w/4 gauge wire i had left over form my amp install, and my voltage increased verry little, my thoughts are that i dont have a good ground in the bellow pics youll see my grounds....
Pic 1 is my alt to positive terminal
Pic 2 is my Ground to engine block... My main concern is that its not a good ground.
Pic 3 is my ground to chassis which dosent bother me much.
l2yan
I put my Ground to engine block in the same spot but put it under the plastic piece with a washer in between. I don't know if it would make any difference for you but i sanded the area to make sure it was a solid ground and also ran tests at both ends of the wire to make sure I was getting a ground. I also used a separate grounding point on the chassis for the the engine block.
After doing the big 3 my voltage was increased very very little if any. So maybe I did it wrong as well :shocked:
The silver wire is the Engine block to Chassis.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Im running a keenwood kac-7204 2 chan. @ 2ohms. i think its 250rms per chan.
Bass boost is set to the middle and bass on radio is set to +4. Im also running stock 135Amp alt and stock battery.
that's your problem. you are asking for about 3x more signal output with those setting s so high.
turn bass boost off. Stop asking for 4x output and sending a clipped signal, or making one via multiple gains (amp gain, bass boost, and bass +4 are ALL gains)
that will reduce your current demands significantly with only a moderate if even noticeable reduction in output.
:hands:
If you need more power, get a bigger amp, and don't try to band-aid it by overdriving the existing amp.
