Loud *clank* sound from engine - 2007 Tahoe 5.3L
H
hound_dog
Thanks Dillon. I dropped it off at the shop on Monday and will be checking with them to see if they were able to reproduce the sound. Thank you for reviewing the video and looking for a solution. I'll take a look now and look for what you saw. Would be great if that's it!
H
hound_dog
The shop said there were misfires in cylinder #1 and #7. Recommended ignition coils be replaced on those two, so they did. Going to pick it up tomorrow and I really hope the clank sound is gone.
Dillon2222
If its cylinders 1 and 7 those are AFM cylinders and you might have a lifter that is stuck, causing the misfire. That can get costly real quick. Still think that noise is coming form the water pump though. JMHO
H
hound_dog
So the morning startup after I picked it up...clank! 5 times actually.
Swathdiver was right...how could this solve the clank? It didn't. The coil replacements were to try to solve the misfires (measured). Not sure if it did anything ask the idle is still a bit rough.
I'm at a loss here. Options are to just drive it until it gets worse or won't run....or maybe take it to the dealership and hope they can figure it out. Since everyone has been stumped, it doesn't seem like it will be an easy fix.
Dillion2222: if the sound is coming from the waterpump ....I should just drive it until the waterpump dies. It's not leaking and not overheating so it seems to be doing its job. Agree?
Scooty
I had an intermittent clank on my 08 just this winter. My mechanic put on a lift and checked everything that could possibly be loose and found nothing. he then started it while on the rack and thought it was coming from the starter. Sure enough after pulling the starter he saw the pinion gear was not disengaging all the way from the flywheel. It was barely touching the flywheel thus causing the intermittent clank. Replacing the starter fixed it...just my experience.
H
hound_dog
Awesome post Scooty! Did yours only do it while cold or also while driving?
Thank you very much for taking the time to read these problem threads and maybe striking gold. I will see what I can do to determine if the sound is coming from the starter.
Scooty
Also while driving. It started the Saturday before Christmas and the local shop I went to was closing early but said he didn't want me leaving on the chance of causing more damage. After he got the starter off you could hear there was something loose in it. He thought the pinion would slide out and hit the flywheel and that would kick it back causing the clank. Again this was my experience ...hope this helps you.
Krbobby
