Low Coolant message
puckhead
CO
Every now and then, especially after off-roading or a medium distance drive I get this message. I always check and the level is where its supposed to be in the overfill tank. I do here the gurgling alot of people hear. Im pretty sure I just got it flushed not too long ago but I gotta dig up my records. Any suggestions?
viximaging
Houston/Spring
This happened on my 01 silverado.. It was a faulty sensor. i removed the harness and put in a jumper wire to trick it until i replaced it and that fixed the problem
yukonjacks
A Vegitative State
The Confluence
Mine will do it if I'm parked facing down hill or if I park and the passenger side is on the low end of a hill, never gave it much thought after checking the overflow once or twice, as soon as I pull out to a level spot and restart the truck its fine once again
puckhead
puckhead
CO
Sweet, good to know it should be something easy and cheap. I wasnt too worried cause my temp was good and so was my level
DenaliAK
Colder than you
Alaska
Had that happen to me once, too. Just once, though. Kinda weird. I did all the usual...checked the level and temp and they were fine. Hasn't done it since.
They're just lights and warnings....they don't mean anything. Just ignore them and keep driving....
:driver:
jhellwig
Ottumwa, Iowa
Mine doesn't work. My 2003 silverado worked some times, usually when it was a gallon or so low.
I wounder if these don't get gunked up.
puckhead
puckhead
CO
keep drivin! thats what im talkin bout AK!mine just has been happening alot and had be worried
Rivieraracing
Check your water pump!! Crawl under your truck with a flashlight and maybe a small mirror and check out the bottom of the waterpump to make sure it isn't wet! I had that happen this summer but it never really looked like it was low, just happened to see a drip under my truck, low and behold the water pump was failing!! Just an idea!
puckhead
puckhead
CO
thanks bud! ill check that out too
bigtoe
