Lower Door Seal
blueinkd
Where can I find this seal? Link would be appreciated as I dont want to order the wrong thing. Vehicle is an 2005 Tahoe LT
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Seal not serviced separate, part of the molding. I won't even put how much that molding is cause you wont believe me.
Had the same issue, ended up getting the molding from the salvage yard. I wasn't aware you could remove the seal, so when I replaced mine I pulled the seal off and replaced it with the one from the yard.
Raptor Tahoe
915_Tahoe
HELL PASO, TX
I checked various suppliers and the best I could find was at: https://www.gmpartsoutlet.net/oem-parts/gm-surround-weather-strip-22766410?c=Zz1ib2R5JnM9ZG9vci1hbmQtY29tcG9uZW50cyZsPTE0Jm49QXNzZW1ibGllcyBQYWdlJmE9Y2hldnJvbGV0Jm89dGFob2UmeT0yMDA3JnQ9bHR6JmU9NS0zbC12OC1nYXM=
Entire door seal is one piece and easy to install with just a trim tool. See YouTube for installation video.
Here’s the part name to search for...
This part you posted is incorrect, the seal is part of the black rocker molding. That molding is about $300+.
blueinkd
blueinkd
Thanks for the replies everyone. Been busy chasing pass side water intrusion, which caused me to forget about this. Got both seats out and carpets pulled up. Water coming in from behind rubber/foam mat against firewall
Mreedini
