Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
What exactly is used in the rear to achieve the 3.5" drop seen here?
Use the 5/8" Heater Hose and not place back in the stock upper spring insulator?
Is this with the 1" Rear Spring Spacer installed or No?
Also you mention that this Escalade has the higher spring rates that GM used compared to other SUV's, and in other threads I think you mentioned that there are two part numbers for the springs one ending in a 7 and one ends with a 2. Do you know which one is the stiffer higher spring rate, ending with a 7 or the 2?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
