So I am looking to lower my 2010 Escalade, most likely a 2/4 kit, I need to replace both front shocks, since they are blown/leaking, so I'm looking to see what kits are available with a new front shock instead of buying new oem shocks, then buying the lowering kit??
this here (http://www.tbssowners.com/store/index.php?act=viewProd&productId=106) is the kit I am looking at getting, but it specifies not for trucks with autoride, are these just a shorter shock to use with the factory spring?
my last truck was lowered on drop spindles, so getting the camber/caster angles was no big deal, will I have enough adjustment after lowering with shocks ?
