Lowering on 24's
Ghostl7
Corinth, MA
In the same boat! Already lowered with 3" coils on stock autoride shocks using shock extenders. Going 4" and need to know if I can use basic air shocks with air line run to manually air up?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
4 inches will need my rear end link and bumpstop kit and cut bracket off frane
BADRIDES
which springs you have in rear?
redeknightjr
i have a adjustable kit 3-4 inch with shock extenders is 250 shipped
Tony, will the same 3-4 kit for an 07 Tahoe need your end links and bump stops? Or, can I get away with just the springs and shock extenders?
1SG Retired
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1SG Retired
I'll be honest here. 3 inches or more I cutty bracket off. If it's a true inch spring if you have people in rear and sint cut bracket will just bounce.
Cut bracket off do endlinks and my bumpstops and your done.
redeknightjr
Thankyou sir
1SG Retired
97ext
