Made boo boo
Code187
Louisville,Ky
Hello, was removing the factory nav unit to install a pac ISGM655 Premium Factory Radio Interface for iPod, iPhone or iPad, Android. When i tryed to pull the radio out the wiring harness was really short and wouldn't allow the radio to be fully pulled out to gain access too the connectors. After working the unit around i was finally able to get it to slide out enough to get to the connectors. Once i had it out i noticed a single green wiring connector still attached to the head unit. Looking further into this there was a single coax cable that was connected too this connector. What is it?. And how would one go about repairing or replacing said coax?. Any help here would be highly appreciated.
PlazaEJ
Post your Year and Model, and I'm sure someone can chime in.
Just a guess, but, could the coax cable be to your antenna? And, the green wire a ground, for said antenna cable?
HTH
EJ
C
Code187
Louisville,Ky
Hello, 2006 Tahoe with Bose factory nav radio. I have found out it is the GPS antenna wire. Now to find a replacement or repair.
conquer1
