Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
Matt_
Following this also as I eventually want one for my 2500 to help with towing.
Somewhat local, in Jackson and play roller hockey at Winding River, friends live in Tom's River too.
Anyone talk to East Coast Supercharging on 539?
I know a lot of Subaru guys who go to Procom and have a buddy who does some side work for them. Also know the guys who own PSI (specialize in harnesses for LS swaps), I think they use Tune Time for a lot of their dyno runs.
In the end I'll probably do my own install and have Black Bear tune it
Is an LS3 a good route for a GMT800? My goal is 500whp for now with plenty of low end and daily driver manners, but a solid platform that I can take beyond that down the road. My current 5.3 has 200k on it..
Two things, an LS3 is Gen IV architecture. You have to decide if the electrical adaptation required is worth it as the GMT800s are Gen III.
Second, dropping in an LS3 crate motor is going to kill your bottom end. The camshaft was designed to move cars around fast, not trucks weighing 2000 pounds more. Most performance camshafts, even the "low lift" cams advertised for trucks, lose a substantial amount of lower end torque and gain it back higher in the rpm band. The is counter-productive for getting a big truck moving and of course, towing.
I read the posts of guys putting in "mild" cams in their trucks and then going with high stall converters and gears because they are now dogs off the line but scream above 4000 rpms. Who drives at 4000 rpms? In my daily travels, mine rarely sees 3000 rpms, the tune and 3.42 gear gets it up to the posted speed limits with little effort.
Just make sure the camshaft is designed to move a heavy truck, not a regular cab short bed that weighs as much as a Vette! And if going with forced induction, mild single pattern cams usually work best in those applications, letting the turbo or supercharger do most of the work when under boost.
Chrismnj
Chrismnj
NJ
Haven't heard of East Coast Supercharging, but definitely will check them out, thanks! what is your experience with Procom? I go to the range in Jackson.
Matt_
No direct experience with Procom, just have friends who have built subi's and spend a lot of time there, and a close friend does CAD work for them on the side. I'll actually be at his house tonight for NYE... have any questions? I'll poke him a bit to see if the procom guys have any experience with the GM engines (would benefit me as well if they do).
A few of the houses I'm looking at are around the corner from ECS, so I'd be interested in their experience too.... might be very local to them soon
muncie21
Having had a few SC'd vehicles, I'd suggest a roots blower, rather than a centri for your tahoe. Roots make max torque just off idle, thus are good for heavier vehicles where you don't want/need to spin the engine to generate torque.
A magnuson install is pretty straight forward and they come with a hand held programmer. Perhaps not the best tune, but good enough to get your to a local tuning shop. Install is pretty straight forward; 2 days (max) with basic hand tools. Net result is ~+100HP, with conservative tune.
Chrismnj
Chrismnj
NJ
so there is no need to send my ECU to them?
muncie21
The TVS1900 kit on their website shows the hand held tuner comes with the 2010 5.3 engine tune. Not sure of the difference between your '12 and the '10s however the tune should be sufficient to get your going, especially if you don't get into the boost. My guess is that because this kit is CARB rated, they don't have certifications in hand for newer motors. Quick call to them would confirm.
The Magnuson SC'ers have a vacuum regulated by-pass valve that doesn't allow boost under low/part throttle conditions, so essentially your motor runs like stock until you floor it.
Chrismnj
Chrismnj
NJ
would you say Magnuson is a best choice for Tahoe?
Mrfirewolf1000
