Making my Yukon XL into an Urban Assault Vehicle
H
hotdog.
Do you think adding an extra inch of cranking on a 3 inch suspension lift would be over cranking? I figured that would just put me at a middle range torsion flex
yates ™
Resident Apple hater
Iowa
It depends on the lift. Post a link to the lift you're looking at for an accurate answer.
YukonXL04
The Riverboat
Arlington, TX
Just buy the 6 inch and be done lol... your talking 2 inch difference over what you want... lol
Those are some serious knuckles on the picture yates posted lol dang...
TheAutumnWind
2" makes a big difference in the stance/look I think. I am about to rip my Jeep's suspension completely apart again for 1" difference.
YukonXL04
The Riverboat
Arlington, TX
2 inch also makes a difference when your out on the trails flexing... I would rather have an extra 2 inches if lift vs rubbing or other clearance issues...
H
hotdog.
Thats the thing, realistically this is going to be 80% on road MAYBE 20% off-road. I drive on crappy roads a lot, but by no means will this be an offroad machine. Not a mall crawler by any chance but definitely not a rock crawler either. Most true offroad this will probably see consistently is a muddy logging road or two.
WHich is what makes me think a key lift makes the most sense. I could get about 2.5 inches from that and then body lift another inch or so if I didnt think it was high enough.
Again, pavement is going to be 80% of what this thing rides on, I just want it to be a snow beast that has offroad capabilities, even if it is only slightly better than stock offroad ability.
With the key lift I will definitely be getting Bilsteins, and probably stiffer springs.
I basically want to correct any issues I may have while sitting at about 3 INCHES of height.
I really want four, but if I can't get 4 from keys (definitely cant) then I'll do a body lift down the line. Currently just want to get a better stance around 3", stuff some 33's in there, paint it, and call it a day. Hopefully with all that done it will sit 3 inches higher relatively safely/comfortably/durably? Yes?
yates ™
Iowa
Being true off road or not you're still going to want a quality lift, you will pay for it one way or the other in the end.
H
hotdog.
Rusty T
