Max tire size w/CCM 2.5/1 kit
felixgun
Lafayette, LA
Thinking about putting the ccm kit on my avalanche. I have Nitto Terra Grappler 305/50/20's on now and I'd like to be a little higher. Do you guys think the tires would look too small?
The Pawnbroker
The Pawnbroker
Annapolis, MD
No they won't. It's not a huge difference but enough to notice. The kit is only $150 and the install is very easy. Can you do it yourself? If so, and you really don't like it, you could easily take it off. I'm positive you wouldn't though. It really just gives it a little more "attitude".
felixgun
Lafayette, LA
Nice. It's actually rubbing a bit when I'm in reverse so I'm hoping it'll help a little bit in that aspect. Now I need to hunt down the cheapest place to buy it online.
Wakinvol
East TN
Yes. I actually called and made the order over the phone. Quick and easy...using the number on the website.
felixgun
Lafayette, LA
Sweet thanks for the info Luke.
Is this the one you bought?
http://www.ccmoffroad.com/shop/index.php?l=product_detail&p=38
It's 129.99 on their website i'm guessing shipping was ~$11?
Also Luke, I see you had it on an LTZ so you do have AutoRide. Did it mess with it at all or everything was good to go? I'm about to pull the trigger on this as soon as I get a confirmed answer.
Wakinvol
East TN
Mine is a LTZ, and the cost was $129 + shipping. I had those same concerns so I called CCM direct. They said it would work...and they were correct. No problems with the autolevel/autoride. The only mod I made was the grinding off of the top nipple on the struts to allow clearance. Everything was fine when I took it off and went back stock. I posted a thread on instillation how-to hints that make it a piece of cake to put on. It is fairly easy
(on a lighter note I found some cheap fender flares that mimic the z-71 ones...makes me want to get them and another CCM and do it all again!)
llisumm
