Max tire width, no lift/level
ljn21
Well shoot. Guess i dont know why i thought it showed a minimum of 9”…it sure as heck is 9.5”…i must have been looking at a different size tire when i saw the 9” ugh. Well, i will see what discount says when they go to mount them up, because i just ordered them.
The 33x12.5 is SHORTER than the 305/45, and is actually shorter than the factory tire. And it is wider than the 305. Neither which i want.
I think a 305/45/22 by math comes out to 32.8” diameter (305/25.4*.45*2+22)
olyelr
olyelr
Elk Rapids, MI
Height wise either would be close enough. But i already didnt really want the 305 width…certainly didnt want to go wider. A 285 would have been more desirable by me.
olyelr
olyelr
Elk Rapids, MI
Well, they are mounted up. 305/45R22 toyo at3’s on stock wheels. She has not reported any rubbing…
d_hawk
Tires look good. Do you have air suspension? If so, could you lower down the suspension to entry/exit mode and crank the wheels left or right and post some measurements of front and back fender liner clearance?
olyelr
olyelr
Elk Rapids, MI
Sorry, does not have the air suspension.
olyelr
olyelr
Elk Rapids, MI
The do look good, not ballooned on the wheels. What kind of air pressure are they running?
I dont know, i will have to get back with you on that.
On a side not, discount tire did not say anything about the manufacturer calling for a wider wheel…they mounted them up without questioning, which is unlike them from my experience. They have dicked me in the past about that.
Roscoe2352
