mattbta
I'm trying to put in footwell lights in my 04. I found this post from 2014 that shows a pin location on the back of the MBEC. https://www.gmfullsize.com/threads/installing-footwell-lights-in-03.104799/post-5720705
I've removed all the plugs on the front and rotated it around, but can not figure out for the life of me how to "slide the blue TPA from the plug" to allow my pin to slide in. That screw in the middle comes loose a little bit, but won't fully remove or I don't know how. It appears the TPA is blocked by the black outer shell around the white plug.
Any ideas? I'd rather not give up on this approach because it's clean and from the factory.
Thanks,
-Matt
Thanks,
-Matt
