Didn't want to hijack another thread ..
06 Denali drove 20 miles. Started again and no OP , bell going off and started to chatter in the upper end. Got a little louder so hauled it home. Had an o ring issue two years ago that did not get caught in time so this is a replacement with supposedly 90k at that time. Suspected an o ring here and that is not the case.
At this point.
Oil ring and pick tube are fine. Both valve covers off and no apparent lifter problems. # 4 main bearing cap pulled and bearing looks new. Just took oil pump off and no broken gears. Not sure on how to check the rest of the pump.
Here is the question. I have a brand new HV pump from the last episode.. long story. I would like to put it on put things together. What scares me a little is that I have had a mechanic say he has seen this pump take out main bearings I guess with too much pressure. It has the spring in it that it came with. Not sure I can find the other one, but could order one I would think. when this engine was put in It ran at about 30psi down the hwy. In thinking back a couple weeks ago I thought the gauged jumped around a couple times and was lower than normal. Do I change the spring or am I worried about nothing?
Thank you
At this point.
Thank you
