Mild Cam....
rican4lfe
Staten Island, NY
Just installed a mild cam on my truck.... all system check ok but when in gear start to go from 750 to 500 non stop when the stoped at a light... fuel preasure reas fine but wonderign if it is enough for the cam???? or do i need to reprogram the comp???? cam is a
comp cam 249-08-300-8
Computer controlled Hydraulic Roller Camshaft
Operating Range: 1000-5000 RPM
Duration Advertised: 262° Intake / 264° Exhaust
Duration @ .050'' Lift: 206° Intake / 210° Exhaust
Valve Lift w/1.7 Rockers: .450'' Intake / .480'' Exhaust
Lobe Separation Angle: 112°
thanks for any input
rican4lfe
rican4lfe
Staten Island, NY
Will be retunning using a dyno hopefully by
October, right now very low in cash. Anything
Else i should look for till then??? Thanks for the input
rican4lfe
rican4lfe
Staten Island, NY
curently working in the more cash situation..... but with this economy is going to be a long, ruff trail to tackle..... thank all you guys for your knowledge....
GoPadge
