Minor performance mods help.
Sandaman
Sandaman
U.A.E.
It's nice and can even bleed the ABS solenoids. But, at that price you may as well spend ~$50 more and get a Tech2 and be able to do just about anything and everything. Something like that Innova would be good if you had non-GM vehicles, though.
Me and my friend wanted to go halfzies on the OBD link mx+ HAHAHA. As he has an Infiniti M45. Or I get the chinese one just for myself
TY
Sandaman
Sandaman
U.A.E.
Hai guys,
Does AFM work (V4 mode) when I am cruising at highway speeds (100mph). Or its in v8 mode after a certain speed.
TY
gat0r
DFW
^ i dont think it does...
there is specific criteria for it
someone will correct me if i am wrong, but pretty sure it doesnt work @ idle & it doesnt work above a certain RPM range. (want to say 3000-3200)
Hai guys,
TY
To provide maximum fuel economy under light load driving conditions, the engine control module (ECM) will command the cylinder deactivation system ON to deactivate engine cylinders 1, 7, 6, and 4, switching to a V4 mode. The engine will operate on 8 cylinders, or V8 mode, during engine starting, engine idling, and medium to heavy throttle applications.
Manifold absolute pressure (MAP) and the conditions listed below determine when cylinder deactivation is enabled.
Engine has been running for greater than 30 s
Engine speed is between 700 and 2800rpm
Engine oil pressure is between 187–455 kPa (27–66 psi)
Engine coolant temperature is between 40–129°C (100–264°F)
Engine oil temperature is between 16–128°C (61–263°F)
Throttle angle is 6% or less
Ignition voltage is greater than 11 V
Transmission is not in first, second, or reverse gear
Vehicle speed is greater than 25 kph (15.5 mph)
Brake booster pressure is greater than 42.0 kPa (6 psi)
Vehicle is not in fuel shut of mode
Vehicle is not in heater performance mode
Vehicle is not in tip in bump acceleration mode
Vehicle is not in oil aeration mode
Vehicle is not in low range (if equipped)
Cylinder deactivation may be inhibited for many reasons including the following:
Engine coolant temperature out of range for cylinder activation
Engine vacuum out of range
Brake booster vacuum out of range
Transmission gear incorrect or shift in progress
Accelerator pedal out of range or rate of pedal application to fast
Engine oil pressure and temperature out of range
Engine speed out of range
Vehicle speed out of range
Minimum time in V8 mode not met
Maximum V4 mode time exceeded
Decel fuel cutoff is active
Reduced engine power is active
Torque management is active
Catalytic converter over temperature protection is active
Piston protection is active, knock detected
Cylinder deactivation solenoid driver circuit faults
Sandaman
Sandaman
U.A.E.
Hai guys,
I wanted to change the spark plug wires on my tahoe. Does this improve anything?
Wanted to know before I bought them.
Heard something like low resistance and shorter cable does increase some performance. Also some different high performance spark plugs.
Thanks in advance
(all you guys are really helpful)
Hai guys,
Thanks in advance
They're the same as gimmicky spark plugs- you have nothing to gain by switching away from stock or stock-replacement. Go with ACDelco, GM Performance Parts or Taylor if you want pretty colors.
Saltyfinfan
