mirror covers
Mr. B
Rockford, IL
Carefully pry them off. Start at a corner, you should be able to see the tabs. Maybe use a flat scraper or screw driver to pop them loose.
zach2011
Platinum Member
There's usually a spot where there's a gap, start there.
Mr. B
Rockford, IL
Start with the passenger side. I have a spare I can give you if you mess it up figuring it out.
blaqout
blaqout
King Yukon
Indianapolis
Thanks guys, I got it off. Pretty easy actually. I used the same tool that I use to remove dash bezels when installing a car stereo. Worked perfect very thin dull edge pryed it right off. I got the Driver's side on I will install the other one (the new one) tomorrow. Thanks again Mr. B!
Mr. B
Rockford, IL
Oh, you re-used your stock caps. Duh, I thought you were taking them off to get painted.
blaqout
blaqout
King Yukon
Indianapolis
Yep. So the turn signals work, but to get the power fold and puddle lamps to work I have to buy a new switch and get it flashed correct?
zach2011
Platinum Member
I've heard mixed answers about getting it flashed. But most likely yes.
Mr. B
Rockford, IL
I'm not sure what you have to do. I have a Denali, so all the options were there. Zach, didn't you change to Escalade mirrors? What did you have to do? Did you have to buy new switches? Did you have to flash?
macking
