Missing Oil
willua11
Alabama
I recently changed my oil and I noticed that only about 3 quarts of oil came out. I change my oil regularly and am completely confused as to why it is like this. Since I've had my 98 Chevy Tahoe 2dr 4x4 I've always have to add coolant to my reservoir or radiator to keep it full. Not a fast leak or anything like that. My first though was that it was getting into the oil, and the problem would be a head gasket, but the oil isn't milky or lumpy. Hopefully one of you has had the same problem and can help me out.
Thanks,
Will
MoroneSaxatilis
Have you pressure checked your coolant system? Might not be a bad idea to start there for the coolant, could be something minor.
ExEvolution
Its not uncommon for these engines to burn a lot of oil
My 96 5.7L 2WD Yukon burns about 2 quarts every 3 months, I usually have to add oil before the oil change is due
bowtiefreak
No Quarter
Near Philly
mine have never burned oil. No leaks?
So the truck is drinking oil and antifreeze? Does the exhaust have a color or strange odor?
98chubby
I recently changed my oil and i only had a half a cup of oil! Came to find out i had a oil leak from the corner of the gasket by the tranny. Have you checked that?
psfr311
Lawrenceville, GA
my truck burns a little bit of oil. usually i have to put a quart in between oil changes. not nearly as bad as yours though
the old engines are known for burning a little bit of oil
willua11
willua11
Alabama
was is leaking bad enough to leave a spot on the ground?
---------- Post added at 05:11 PM ---------- Previous post was at 05:11 PM ----------
the exhaust doesn't smoke at all either
98chubby
yes it did show on the ground but i guess it spilled more when i was driving
willua11
willua11
Alabama
So it was obvious where it was coming from?
I just know I haven't seen ANY on the ground.
gpracer1
Phoenix
First thing is you have to actually VERIFY for sure that it was full with 5 quarts.
Who changed the oil last?
I saw a tech once fill his own car twice in the dealership I worked at.....his wife left and the poor RX7 was smoking like a wildfire. Same dealer, guy got his Miata back with no oil at all!!
SuitedSevens
