More Lift Questions With A Specific Goal
Dustin Jackson
@blackelky According to this post the 81071 are standard height and the 81069 are factory lifted like the z71
blackelky
Thanks I can't tell if i need new springs but the ride does seem bouncy. I don't get it because it doesn't even have 100k yet and i changed the shocks to billsteins
steiny93
@steiny93 You can get 33 inch tires with stock wheels, just need to get larger tires
I mean can't you get 33" tires to fit by getting wheels with different offsets then then stock tires? Vs having to lift.
I have a 2008 with a 4.5 lift and a ton of cutting to fit tracks, the lift really destroyed the ride.
Dustin Jackson
@steiny93 it depends on your setup. I think you can easily fit 33x10.5 tires on factory wheels and factory suspension.
But if you get wider tires like 33x11/12 you’ll rub on the control arms and then you need offset wheels for clearance.
Once you do that you’ll start rubbing on the fenders and you’ll need to trim.
It’s a whole chicken egg situation.
The wheel wells are very square so I think you’ll get the same amount of clearance with a level kit and a 3inch lift. It isn’t once you start getting up to 4 inches of lift that you actually start to get the tires outside of the square wheel well.
Nix409
