YukonCrazy
135K
Driver side is fairly easy I don't have any videos but I do motor mounts on Border Patrol tahoes once or twice a week so I can give you my advice and I'm sure others will chime in. The easiest way I have found is to jack the vehicle up and lower vehicle on to jack stands, remove the driver side tire and plastic fender liner most work will be done through the wheel well, remove the exhaust manifold heat shield or tweak it a bit for extra room, then support engine with a jack and piece of wood (under oil pan is ok), remove the short section of the steering shaft from firewall to power steering rack and then loosen the 3 bolts holding mount to frame then you can lift the motor up with the jack and have easier access to the 4 bolts holding the mount to the engine block, then wiggle the mount out through the top and reverse steps for install, all bolts should be a 15mm, you can also use a pry bar to tweak the old motor mount heat shield for more access to the bolts. Hope this helps!
