nadthomas
- Joined
- Dec 1, 2017
- Posts
- 158
- Reaction score
- 177
So, for anyone that has been follow my build thread, I pulled the motor out of my 2007 Yukon Denali with 192k miles over the summer to replace the oil pump, refresh all of the gaskets, fix the broken exhaust manifold bolts, and address a handful of other things while also doing a lot of cleaning and degreasing. I also pulled the transmission valve body to inspect it and to check for worn check balls. I finally got everything back together over the weekend that is needed to fire her up. I reconnected the battery, and go to start it up.
The first thing I did after turning the ignition to on, was cycle the gear selector to make sure the vehicle was in park. I only drove this vehicle occasionally for the few months I owned, so my memory could be fuzzy on how a few things work on this vehicle. I noticed the the gear indicator on the dash did not change at all as I moved the shift lever. Shouldn't there be a line or some sort of indication of gear change even with just the ignition turned to on?
Setting that aside for the moment, I proceeded forward and turned the key to start. The radio and dash reset, so I assume the battery was weak after sitting for 4 months, and apparently at one point I popped the rear glass so I'm not sure how long the battery was connected with glass popped. So I could have drained the battery pretty good. Off to Autozone to have them test and charge the battery. They said the battery tested good, and charged it for about 1.5 hours. I dropped it back into the Denali, test the voltage which read 12.3V on my multi-meter. Attempted to start, and got the same thing. No start, no crank, gauge cluster blanks while the key is in the start position and resets when release. So, I started to research and diagnose.
When the key is turn on, I believe I hear the fuel pump prime, but its kind of hard to tell since there are several things that make soft buzzing and humming noises when you turn the key to on.
I don't believe its a key transponder issue with the Passkey III security system. The light for that on the dash lights up when the ignition is turned to the on position, and then turns off after a few seconds.
The starter is new, and when put a screwdriver across the terminals it certainly spins.
One thing that leads me to believe I have an issue with the computer or communication issue with the computer is that the fuel gauge never moves and is on Empty.
Following some of the diagnostic test from this video.
With the ignition on, I tested with a test light, and have power across Fuse 56, 12, and 4. I also have 5V reference on both the MAP and MAF.
So, I'm a bit stuck at the moment. I bought a trickle charger to ensure the battery is fully charged, and I bought the VXDiag VCX Nano GDS2 which should give me a Tech2 virtual machine that I can run from a laptop. I'm hoping once I have that I will have a lot better understand of what the truck can and cannot talk to. I'm open to any thoughts or inputs, or even steps I should take once I have access to Tech2.
