Motor swap prices?
Administrator
Pretty sure they will not...
bkboatnsleds
McHenry, IL
Will headers for the 5.3L. Fit the 6.0L?
Yes - infact.. If you are putting the 6.0L in place of the 5.3 you need to order headers for the 5.3. (if you plan to use stock down pipes) The passenger side pipe has a different end on it than the drivers side (on the 5.3) the 6.0 stock they are the same - and it does not match the down pipe in the truck.
So if you are going to do shorties or even keep stock headers you have to use the 5.3 ones on the 6.0 in order for it to match the down pipe. Learned the hard way! lol
---------- Post added at 12:51 PM ---------- Previous post was at 12:50 PM ----------
They should fit, actually. The 4.8, 5.3 & 6.0 have the same header bolt patterns.
Correct - the difference is where it meets at the down pipe.. Drivers side they are both the same - pass side the 6.0 is different.
---------- Post added at 12:56 PM ---------- Previous post was at 12:51 PM ----------
Here is an example of ones that fit the 4.8 and 5.3
The ones ordered for a 6.0 look the same but the one side does not have that male flange on it (which fits into the stock down pipe)
Administrator
:hmm: Learned something new today. I had no idea that the bolt pattern for that on the 4.8, 5.3 and 6.0 were the same. I just always made the assumption (albeit wrong!!) that they were different :shrug:
bkboatnsleds
McHenry, IL
Yep the blocks on these motors are all the same - pretty much just bore + stroke difference -
bkboatnsleds
McHenry, IL
So my LT headers on my 5.3L will work on the 6.0L
That is correct. The only difference is where the headers meet the y pipe.
The 4.8 and 5.3 have a flange on the passenger side header that the 6.0 header does NOT have. Which also means the OEM down pipe on the 6.0 trucks is different -
The drivers side header is the same on all 3 motors. Clear as mud - right?
here's the bottom line - If you are putting in a 6.0 into a 4.8 or 5.3 truck, and plan to keep the stock cats + down pipes you HAVE to use the headers from the 4.8 or 5.3 motor. Even if you want to order aftermarket shorties (Like I did) Order them for the 5.3 NOT the 6.0
Z-56 Hoe
What do I do????
Houston
I have a 5.3L no and want to do the 6.0L swap right now I have full exuast (sp) I have the Dyantech long Tube headers with the free flow cats! so will they work? they were $1400.00 and I dont want to spend that again!
P.S. I know that there are other cheaper ones out there but I really like this setup alot I have it on My F-150 too! and about to get it for my 08 NNBS
blueflamed03
Oklahoma
they will work, just need to mod Y pipe. all LS ( 4.8/5.3 and 6.0) are exactly same exterior wise.
bkboatnsleds
McHenry, IL
Well it sounds like he has eliminated the y- pipes.. You have custom exhaust literally from the motor back? If so, yes - this will still mount up.
imtye11
