Welcome to this great forum. Already a very interesting build.
I was a bit busy today. I worked on the back tire carrier.Update.
A few more pics.
So i took a week now off back at it. I finished the RC front 3,5 susp lift install. i did the back last week. It was easy they provide upper control arms and new loaded struts. I changed the lower ball joints while in there. The provided spacers to lower the front diff was not a big deal and cutting the lower tie bar to allow the diff to lower and clear was easy. I beefed up the lower bar after cutting it not sure if needed but was easy. I ordered the RC hidden winch set up for a 1500 series chevy. Ill modify it to work as seen on you tube it fits so well i don't understand why they don't list it for Tahoe's. Ill post pics on that as well.Welcome to the forum from Nothern Idaho! Looking forward to seeing the progress of your build.
Michael (Pete the pug) I like you we think alike.
Maybe once it gets close well look at a ring mount and belt fed on the roof.
Tomorrow i plan on getting the rear bumper close and moving on to the front. My brains working on a concealed winch behind the bumper and some D rings for tie downs on the front bumper. Looks like they dont offer much for the front winch mount 07-14 tahoe so ill sharpen the torch.
I have a pressure gravity cup spray set up coming to be able to put down custom coat bed liner smooth. I do alot of collision work but havent played with bed liner yet. looks like a 1.8 or 2 nozzle with a pressure feed gravity cup does well with laying down bedliner smooth. custom coat makes a USMC dark od that i think ill run with.
That @Fless guy, is smucking fart, isn't he.Looks good!
Tip: if you want to "tag" someone (like @petethepug) so they get notified, use either the "Reply" feature at the bottom of his/her post (like I did above), or start with the "@" sign, then start to type the username. A dropdown list will appear.
Like this (as an example):
Select the username from the dropdown -- @zcb350fb -- and continue writing your message. If you don't use either of those methods your target might not see your question.
