Your ECM uses O2 data to determine fuel ratio. If it’s in doubt it will run rich as a safety measure so you don’t burn a piston from being too lean.The Range AFM delete is on my list but I wanted to make sure my shop couldn't just do it for me before I shell out $200.
You think an o2 sensor/wire could cause such a mpg loss? You know, come to think about it my son walked behind my truck last month and said it smelled rich. hmmm
I also put 37 inch tires on it the same day the T-case was changed....I wonder if that could be.....Im kidding.
