I've done some searching and have found some references to MPG gains with some performance mods. My question is, what performance mods will also improve gas mileage?
So far the most popular seem to be:
Efans
Underdrive Pulleys
Electric water pump
For those of you that have done these mods, what kind of MPG gains did you see? Even if you did several mods at once, I would like to hear what kind of MPG results you got from whatever you did.
I saw alot of old threads dealing with Ewater pumps but the concensus was nobody had found one that would work with the Vortec. Has anyone found one for the Vortec?
My problem is, everybody I asked said that I would see a 1-2 MPG gain by swapping to 4.56 gears to handle my 315/70R17 tires. I haven't seen any MPG increase, if anything it got a little worse.
I did see a definite performance gain after installing the lower gears and the performance improved even more when I had a local guy tune it with a Laptop program but after 2 tank fulls of easy driving I have gotten identical 12.7mpg results. I stayed under 2000rpm for the most part. With my setup 65mph = about 2150rpm, so you can see I have been really babying it to stay below 2000rpm.
Is that the best I can expect from a stock 350 Vortec? The Hoe was already lifted when I bought it so I don't know what kind of gas mileage it got without the lift and oversize tires.
Also, I have the Autotrac transfer case. Could that be the poor gas mileage culprit, since it turns the front drive shaft all the time even in 2wd?
I know there are some of you that have your Hoe's setup similar to mine, how is your gas mileage?
My older Hoe (stock 95' TBI) with 3.73 gears and 265/75R16 tires gets a solid 14mpg and sometimes a little better. I know comparing the nonlifted TBI to a lifted Vortec is like comparing apples to oranges but I was hoping the Vortec would do better.
Efans
Underdrive Pulleys
Electric water pump
