MTX Thunderform or JL Stealthbox center console subwoofer
okfoz
I am considering getting one of the following, I will consider a different unit if I come across it or is mentioned...
Here are the Contenders:
In one corner we have the MTX Thunderform. The enclosure is made of all plastic, comes with a speaker, hookups and even an Amp that is designed specifically for the unit, they ask whether or not it has BOSE or not, so it might be a plug and play. They also have a non amplified version and possibly a non speaker version.
Amplified version uses a 10" speaker, 200 Watt, 4Ohm, 2 year warranty
The Amplified version ready to install around $510.00 (Free Shipping)
NON-Amplified Version: $340.00 (Free shipping)
In the other corner is the JL Audio Stealthbox. This enclosure is carpeted, so it has a more "factory feel" It only comes with a non amplified version as far as I can tell...
10" speaker, 300 Watt handling, 2Ohm Mono, 2 year warranty.
Price with speaker $650
1) I am not trying to thump (getting too old for that) I just want it to have a bit deeper kick than it does now. Bit of an audiophile...
2) Price is a no brain decision between the two, MTX is $140 less AND it has an Amp. BUT, if anyone has experience with both, or has an opinion why would I go with the JL Audio?
Thanks
O
okfoz
The link you gave me was for the center seat style console...
The obvious advantage I would see with the JL or tha bare bones MTX is you can pick your own amp, and you get a bit more power. Accessing the sub volume would be easier as it would be remotely placed.
The advantage with the all in one enclosure would be everything is a matched set, they are designed to work together. Getting to the controls I think would be a PITA, but once you get it set up, it should be a no touch situation.
John
blue4d
I recently swapped out the stock console sub in my 07 Tahoe. I went with this sub/box combo and this amp .
I requested the dvc 1 ohm sub without any issues to run the amp at 2 ohms. I already had the necessary wires/accessories to hook it up. It's substantially more powerful than the factory setup, but not overkill.
The amp fits nicely under the passenger side rear captains chair too.
TowGMC
Wheaton, IL
Any idea if it works with the rear A/C? MTX and JL do not.
O
okfoz
Do not be confused.
Having rear A/C does not mean you have rear vents. Some vehicles like Trucks had the rear vents inside the console because there was no place to put a rear A/C unit, the Tahoe/Suburban/Yukon/Escelade If you have the rear A/C unit behind the RIGHT trim panel, you would not have the vents.
My 07 Tahoe LTZ does NOT have the vents in the rear of the console. It has the rear A/C however,
John
---------- Post added at 09:11 AM ---------- Previous post was at 09:09 AM ----------
In short, the only thing going from the front to rear is the wires for the controls.
Check the rear of the console and look for the vents...
---------- Post added at 09:15 AM ---------- Previous post was at 09:11 AM ----------
I think where the problem would come in would be most likely with the Avalanche, As I am not sure where they would put the rear A/C other than have a blower and vents in the rear console like my 2005 Rainier.
O
okfoz
I believe this is the rear vents that they are referring to:
O
okfoz
This should be ok, if the description is correct.
Jybfan04
