My 07 Denali XL 'build'/Check Engine Lights/Questions
C
carrmann
Unless your motor was built before April 2005, it should not have a screen under the oil pressure sensor.
Have you pulled the valley pan to check the condition of the VLOM tower o-rings?
Not sure how to check that, but its a 2007 yukon xl 6.2. So I dont believe it was. Should I change the sensor anyways or nah?
I have not had the intake manifold off. Is VLOM dod/afm related? I don't believe I have any of that stuff, or would I still have it? I had to google VLOM to be honest, so I'm pretty clueless right now about that.
A friend suggested oil pump? That doesnt seem likely to me, but I really am unsure.
Geotrash
Dave
Richmond, VA
Not sure how to check that, but its a 2007 truck. So I dont believe it was. Should I change the sensor anyways or nah?
Nice job on the pickup tube o-ring!
On the ‘07 6.2L the block is cast with the towers for the AFM system and they’re drilled with an oil port. But since GM elected to not use AFM on that engine, they used a flat valley pan with o-rings on the backside of it that seal the towers. Over time, the o-rings get hard and the valley pan bolts also lose their torque as they do, allowing oil pressure to bleed off. The fix is to either replace the valley pan or plug the towers with a plug designed for it, and at that point since you’re in there you can replace the oil sender.
But in my opinion your pressures are just fine.
Let me add to Dave's post. The very earliest Yukons and Escalades had L92 engines with AFM components installed but not active in the tune. Either way, the o-rings on the valley cover can be a source of oil pressure loss.
If the valley cover under the plastic intake is flat, your motor doesn't have AFM. Like I said, whether you have it or not, it can bleed off oil pressure if the o-rings for the towers are leaking. You first remove the intake manifold and then can access the valley pan cover. Get new gaskets for each due to age.
C
carrmann
ok thank you, I will check that then next! Much preferred to crawling on the ground for 6 hours haha.
C
carrmann
any chance that you know what hot idle in gear should be for this motor? I've read multiple different numbers. 550rpm seems low to me(verified with tech 2), but I'm also used to older engines (carb). Thanks!
It's usually between 500-550, as low as possible for emissions purposes. The computer controls the idle based on many factors such as load, air temperature, transfer case position, the weather, etc.
BlackBear Performance usually raises the idle speed 25-50 rpms so that they idle better and to reduce some engines' tendency to stall when you let off the gas too quick.
Just like the older engines, a more aggressive camshaft will idle higher.
C
carrmann
Oh ok, well there goes that idea! Its at about 20psi idling in park when hot (about 600 rpms).
I'd rather get a tuner, as I will probably dabble with some mods on it after I get everything fixed (longtubes, cam, exhaust most likely).
Yessir, more aggressive camshafts pull less vacuum so they have to idle higher or brakes etc have issues.
I need a valley pan gasket, the VLOM o rings, and a intake manifold gasket. Any particular gasket brand I should go with, or stay away from? Or a part # for these, like a kit?
Does AlldataDIY have that info?
Geotrash
Dave
Richmond, VA
New flat valley pan and gasket, GM 12598832
Be sure to replace the oil pressure sensor at the back of it as well.
C
carrmann
I'll be replacing the oil pressure sensor for sure while I've got it apart! Thanks Geotrash!
I found that my rear shocks are blown(air shocks), and while I've been exploring in the engine bay found that the front shock electrical? connectors are no longer connected to the front shocks (up at the top I'm assuming), and the front shocks have coil springs on them. I'm assuming the front shocks do Not come with coils so someone already converted the front to non air suspension?
Also found it doesn't have a front sway bar, and someone snapped the mount bolts off on the passenger side for the sways, so thats going to be a very fun fix!
Rusty T
