my 2002 tahoe build
Tahoewhat
Ballin' on a Budget
TX
:hat: Looks, sounds like crazy build, but looking forward to pics..
dy_lon
Awesome idea for the fuse block. Im going to look into building a similar fuse block, but for my lighting!
flashlight_65
flashlight_65
camp lejeune, nc
i got some old pics that i didnt get to put cause my sd card reader shit the bed on my laptop.
heres of the alts when installed them
more of the interior
---------- Post added at 11:39 AM ---------- Previous post was at 11:39 AM ----------
second skin
2 layers on the roof
1 on the floor on the flat ares 90% coverage and rcas and 12g stinger wire under the carpet for the doors and wire ran for the a-pillars and kick panels for the future
hids and clear headlights/signal lights
before
after
flashlight_65
flashlight_65
camp lejeune, nc
headunit before
bluetooth
---------- Post added at 11:42 AM ---------- Previous post was at 11:41 AM ----------
some equipment
100' 1/0 kolossus flex and 8g, fuses and a ton of ring terminals
buss bars i drilled out but the metal is too thin so i got some 3/4" thick on the way
NoPh33rRaCiNg
Kent, WA
Shoot if you come out here I want to hear this for sure. Question though, where'd you get your ring terminals from? I got a guy on CA and CACO with some but if you've got another source that maybe is cheaper lemme know.
flashlight_65
flashlight_65
camp lejeune, nc
this is where i got mine
http://www.darvex.com/store/pc/view...p&ProdSort=1&page=2&idCategory=22&viewAll=yes
but i got the ones for my caddy here
http://www.thenerds.net/METRA.METRA_Gold_Ring_Terminal.GRT3.html?affid=4
---------- Post added at 12:38 PM ---------- Previous post was at 12:28 PM ----------
Damn, lookin good. Do you have anything else planned for mids and highs
thank you, i already have the infinity kappas for the doors but still undecided about the a-pillars and kick panels (maybe cdt or rainbow comps) as for power an rf t600.4 for the infinity's and a t400.4 for the others
---------- Post added at 12:42 PM ---------- Previous post was at 12:38 PM ----------
Those alts are sexy, and that fuse block is badass. Where do I get one?
As thehoe92 said i just one of the BTL's. The box build starts tomarrow. WOOT
i built the fuse block using an old pelican case, grommets, spray painted some framing brackets and some nuts,bolts and lock washers. good luck on your build
flashlight_65
flashlight_65
camp lejeune, nc
anyone have experience using sketch up? if you guys can help me out im thinking subs up port back with the slot kerfed and centered the max dimensions are 48w x 21h x 22d for 10 cubes tuned to 32hz. any help wou;d be appreciated
flashlight_65
flashlight_65
camp lejeune, nc
Well the box is built. Now I'm working on a new build for the next step
built it in my room
getting the kerf lined up
making it strong
rounding over the corners
---------- Post added at 11:30 AM ---------- Previous post was at 11:20 AM ----------
Seperating the chambers
cutout the holes and test fit
Filled in the screw holes, sanded, glassed/45'ed all the corners
sprayed the port with splatter paint
---------- Post added at 11:41 AM ---------- Previous post was at 11:30 AM ----------
Wrapped and ready to load. Just needs some finishing touches
4.75 cubes after displacement tuned around 32hz
---------- Post added at 11:46 AM ---------- Previous post was at 11:41 AM ----------
What do you guys think for a temp box and first time kerfing wood? I think it cane out all right.
mrtrill
ATL
camp lejeune....damn thrill seekers!!!
lol...im sittin up here lookin @ all those wires n stuff,
its not even mines & im cringing.
great diy though, sum of yall b gettin to it!
by the way...how much amperage does a stock altenator put out??
mines is starting to lose it...I have 2 yellowtops and it was puttin out a steady 14 volts with a 3000 rms draw,
now even without any of the 3 amps installed, that sucker will drop down to 9 volts.
scunningham
