My 2003 Yukon build
franky996
Austin Texas
So the engine in my '03 Yukon XL decided to crap out on me last summer and I have been gathering parts and building it up since then. The whole process was pro longed due to the pandemic and parts being on back order etc
At first I just wanted to put a rebuilt LQ4 in it that I had sitting in my shop. The engine was a short block. But then of course you start to think and it all goes downhill from there
Ordered some Texas Speed and Performance heads and cam shaft , push rods, double roller timing chain set and a GM High Performance oil pump
The heads are the PRC 220cc-15 degree heads, .660" Dual Spring Kit with Titanium retainers , 61cc
Camshaft is a TSP 224/228 .600"/.600" 112
Intake manifold is a Holley High Rise EFI intake with my own carbon top and a Nick Williams 103mm throttle body and 42lbs injectors
Headers are Speed Engineering long tube headers that I coated with ZyCoat heat coating
The headers are attached to the heads with Stage8 locking fasteners
Transmission is a Monster Transmission 4l65E
SS Mega Monster rated at 650hp/600TQ , Thor torque converter 1800-2000 stall with lock up, billet oil pan with drain plug
The rear end was rebuilt, new ring and pinion gears, bearings etc and a Yukon gear limited slip. Powerstop disc and pads
F
franky996
Austin Texas
I also got the electric fans and harness kit.
Most of the work is now done. What's left is making some fuel lines to put the fuel pressure regulator in line and mount it somewhere convenient. And the vacuum lines and wire harness from the old intake need to be made look pretty and re routed a bit. If anyone has done the Holley EFI intake and has some pictures of how they did it that would be helpful.
Really excited to fire this thing up for the first time. Then get it tuned
Def gotta get a video of the start up and it running.
corvette744
2004 Z-71
Northern illinois
Dam that is one nice looking setup.
fasteddy
OMG
That's intense!
Nice lid for that high ram.
Very nice heads.
Lots of Gen3 HHR installs over on LS1Tech.
And they make all the adapters for sensors and vacuum stuff.....just have to hunt it down.
I'm more interested in the injectors to power that system. 42lb ers minimum I'd say.
and fuel pump....you're gonna need 60lbs.
Today I was able to finish the last bits of the install and fire it up for the first time. Love how it sounds. Next is let it run longer and drive it around for a bit to make sure the transmission shifts and the rear end gets settled in, then dyno tuning time
Short clip of it running
Sounds mean. :head3:
Sounds like a beast! I live that intake. Do you know what you're putting down to the wheels? Of course we'll need a video on your 1st test drive. What are you doing for exhaust?
rickprado
