Cattivo
I think I like the lower mounting look better to flow with the fogs. Hmmm either way works, but under is my vote.
Lower definitely looks better I agree, next warm day I'll throw something together to make it work
Nope, it's Satan! But, make sure once you do the knock sensors, you do the mod with the rtv. Knock sensors usually get filled with coolant, which kills them, doing the rtv deal stops that from happening. Hopefully your knock sensor harness is good. They sell those separately fyi.The Hoe is running like shit right now, misfires on multiple cylinders and keeps stalling at red lights, keeps throwing bank 1/2 system too lean codes. I've replaced every possible part that would cause these problems and have narrowed it down to being a bad intake manifold
I just ordered an ac delco intake manifold along with 2 ac delco knock sensors since I'm going to be in there I figured why not replace them... am I missing anything or are my suspicions correct that satan himself has possessed this damn truck lol!!!
I know i read your build yest but i forget if you changed gas filter? Fuel pump maybe going but it really sounds more like a vacuum leak. You got a new maf when you swapped cai out right( im pretty sure i read you did that and that you got a new one) i know the late 90's to early 2000's intake manifolds used to go bad so sounds like your going in the right direction, sorry man.
Lmao, that's exactly me....rtv thing is either making a dam with it around the sensors or filling them in with the hi temp crap so the dont fill with water and crap out again...something like that.
